08 Jeep 4 15'' HDC315-A Build
That says something about the alt its self then I would say. I will be interested to see what they can do now that they haven't been able to in the last two alts:crazy:
yeah. the alt will get oven hot 300+ in secound after starting the jeep. All my batts sit @ 13.2v each.
You don't drive around daily with that regulator turned up do you?
i have my shit set to 14.8 when not bumping. but put it up to 15.3 when kick'n it down hard. always trun it down when the alt cant keep up and give it a few secs to build up power
This is from MissingLinkAudio when i asked diff between his module and an ext. reg alt:
The main deference is our modules fluctuate with your systems needs and
the external regulators have 2 things that we don't recommend 1) they are
hard on things because they don't fluctuate with your system and try to
hold voltage which when alt is trying to protect its self which causes the
alt to over heat and FRY. 2) removing the regulator to external takes away
the heat sencing which leads to the same outcome Fried alts.
Get rid of the ext. reg ASAP
so i should get mla
mla makes them for 08 jeeps gc?
step 1: get money back from mechman if you feel you should be fully reimbursed.
step 2: with that money, buy 2 more stock alts,
step 3: go to local machine shop, have them fab up a bracket for the three alts, there may be a way to have the fit fine under the hood (less than 100 bucks)
step 4: go to auto parts store get a custom length belt.
install stuff
enjoy over 400 reliable amps of charging current
step 1: get money back from mechman if you feel you should be fully reimbursed.step 2: with that money, buy 2 more stock alts,
install stuff
step 3 im ****ed on
MasterOfAllBass
Team Minnesota's Loudest
MasterOfAllBass
Minnesota
EXOcontralto
