flyfishfreak
I am looking for a custom designed enclosure w/ intergrated amp rack. I would prefer the box to sit underneath the rear seats. The Titan is a King Cab, not a Crew cab (4dr). I know tech12volt makes a box, but I just want to brainstorm some other ideas, since this is a DIY project, well for the most part. I guess what I am mostly looking for is someone who has experience working with a Titans cg. I would also like to have some form of plexi cover for the amp space, as I am going to intergrate cooling fans.
Amp Rack
Needs to fit Three(3) amps @ L x W x H 6.3 x 9.6 x 2.5 (in).
Subwoofer
Depth 5.35"
Diameter flange 10.6"
Diameter cut out 9.45"
Znom 4 ohm
Re 1.7 ohm
Le 1.5 mH
fs 39.0 Hz
Qms 6.79
Qes 0.47
Qts 0.44
Mms 121.1 g
Cms 0.14 mm/N
Sd 333 cm2
BL 10.4 N/A
Vas 23.6 ltrs
Xmax 12.5 mm peak
Voice Coil Ø 51 mm
Sensitivity
2.83V / 1m 92.2 dB
Power (IEC) 200 W
Magnet weight 2.4 kg
Thanks
Amp Rack
Subwoofer
Depth 5.35"
Znom 4 ohm
Re 1.7 ohm
Le 1.5 mH
fs 39.0 Hz
Qms 6.79
Qes 0.47
Qts 0.44
Mms 121.1 g
Cms 0.14 mm/N
Sd 333 cm2
BL 10.4 N/A
Vas 23.6 ltrs
Xmax 12.5 mm peak
Voice Coil Ø 51 mm
Sensitivity
2.83V / 1m 92.2 dB
Power (IEC) 200 W
Thanks
