06 Dodge Ram Install Issues
ryderfan81
So I've had an fairly serious electrical issue while installing my new HU.
I have a 06 Dodge Ram 1500 with the 4 speaker system, it has the REF stereo. I installed a Alpine IVA-D106 (with sirius sat and nav), with a PAC C2R-CHYNA wiring harness, and a PAC TR-7 universal output module (for bypassing the park brake lock out for using the nav while driving).
Everything matched up good, no issues while wiring. Had the neg battery terminal disconnected while I removed the old HU and installed the new HU. When I had the new HU in, I reconnected the neg battery terminal and started the truck.
Everything was cool, new HU looked good, everything seemed to work, but ..... I had a bunch of lights on on my dash, ABS, Park brake, Serv 4wd, etc. So I put the old HU back in to see if it fixes the problem, no luck. i took it to the dealership and they think that the TIPM (totally integrated power module) has failed. About a 1000 buck touch!
Has anyone had a similar issue, I triple checked the wiring, and had 2 friends look it over, and it looks good. So I'm not sure if it was a coincidence or if I did something wrong? And if I should try again when I get the truck back.
Any thought would be appreciated, thanks!
ive had to replace my tipm. they are a big problem on the 06 ram pickups.
but, theres is an option you can do and will most likely solve your problem. they can reprogram it, they would rather sell you the 709.00 dollar tipm though......
So, was it a similar issue, or what caused your TIPM to crap out? I've heard something about having the battery disconnected for too long, but i don't know. I'm just worried about trying it again when I get the truck back, spending a lot of money to fix it, don't want to send more getting it installed if i don't have too!
no i doubt your tipm went bad from just disconnecting the battery. unless you shorted something out. usually they go bad my certain things not working.
for example.... headlights, taillights, interior lights, blinkers, just certain things stop working.
i bet you could have your tipm reprogrammed and it will be fine....
I so agree with everyone else about the tipm. Mine went out after hooking up a boat trailer. Right now I have no speedo and have a cel, abs, and brake light on on the dash. I work at a repair shop and have done alot of reasearch on this and yes, it is a known problem. I would install the hu again and then take it in to be reprogrammed.
Ya, maybe i would reinstall it if they can reprogram it. if they can't, i think i'll take it somewhere to have it installed (the hu). i don't want to chance buying another tipm!
ryderfan81
ryderfan81
Pincher Creek, Alberta, Canada
ryderfan81
