06 Chevy Crew Cab
You can search image dynamics site. There was an installer that built a box to hold 4 12's another held 3 15's. They moved the rear seat forward by 1 inch to get enough clearance and air space. That is the most I have seen done in regards to adding bass and retaining the back seat.
There are some fairly good options with dual down fire tens. http://www.caraudiofactory.com has a down fire option and a rear seat option. I would recommend the down fire option as I had some rattling issure with my prior rear seat box. I guess you could take the time to sound dampen the rear plastic under the rear window that should cure the problem... JL also has a stealth box that will go behind the rear seat with space for an amp between the two seats. http://www.subthump.com also has some nice boxes. http://www.bassforms.com has another ported 10 option.
The downfire option will give the most bang for the buck with minimal alterations. Good luck, do a lot of searching before you decide.
Anyway, you have several choice... good luck!
Rsahota112
Rsahota112
fresno
IM IN HERE
BP1Fanatic
BP1Fanatic
