0 gauge power and 4 gauge ground?
Z4CK
I'm going to be using a AQ1200d and since it only accepts 4 gauge i'll be using a reducer from the 0 gauge power to the amp. I was wondering if I could use 4 gauge for the ground to the car, would this cause any problems?
I'm not doing it right now but I was just asking if it would be okay because im trying to save money, it would probably look ghetto so nevermind i'll just go with 0 gauge and 2 reducers.
You're fine the way you are. You shouldn't have any issues. The amp is designed for 4 gauge so using a reducer on the power and 4 gauge on the ground will be fine.
As it has been stated above, your ground wire should be at least the same size as the power, you can go w/a bigger ground too as long as the power and ground wires are the required size.
Not "right", but not a problem.
Whether it's 4 ga, 1/0 or 4/0...there will be a small amt of resistance there, just as there is in the power wire.
4 will have more than 1/0, but still acceptable for that amp. It does kind of defeat the purpose of running the 1/0 on the (+) side though.
Z4CK
Z4CK
Houston
n2audio
