loc issues
  1. DJG0817
    LC7i Voltage Question
    I have a 2021 F150 with stock non-amp HU ==> LC7i ==> Kenwood 5-channel amp. The kenwood amp will handle 5v on the RCA inputs. I can get the LC7i to about 3v output before the LOC clipping light (maximized light) comes on (HU @ 75% / 1K sound file). Should I ignore the clipping light and...
  2. Cataldo04
    Subwoofer issues
    I am using a line out convertor in my 2009 grand Cherokee and it worked perfectly for around two weeks and then suddenly stopped I have the amp hooked up to an eight inch kicker slim sub in a kicker wedge box I hooked the power and control up to a switch because for some reason the amp would not...
  3. Platinum1959
    Connecting Car Bi-Wire Speakers to a Vibe LOC or direct to a Powered Vibe Subwoofer
    Hi there I have looked everywhere Online and nobody is discussing this common LOC connection I am trying to get an an output signal from my car's rear Left door Bi-Wire Speaker and connect it either to a Vibe CLLOC-V7 or Direct to a powered Vibe 12 Inch Subwoofer. Can somebody confirm if I...
  4. I
    No audio out of stock speakers when sub is on?
    Hello, I have a 2006 Honda Civic, running a Boss R110m amp with 2 8ohm subs in series, using a PAC-SNI 35 LOC, with stock head unit. I have the amp powered getting the remote turn on wire from a fuse in the fuse box, and I will be hooking it up to the proper wire soon, but for now it powers on...
  5. X
    Issue with LOC and remote turn on.
    I bought an LOC2 and wired it into the harness that plugs into the head unit, to convert it to RCA for my amp, but the amp won't turn on, because it isn't getting any power from the remote turn on wired to the LOC. The only reason I can think for why this is happening is because I didn't wire...
  6. D
    loc problems
    Recently installed an amplifier in a 06 lexus is250 wired in a dirt cheap scosche loc-80, for the input wires i used the factory subwoofer wires coming out of the factory amp. Upon testing I found no sound from sub, all powers and ground ok, my question is do i need to tap into a set of wires...
  7. M
    2011 Honda Civic LSX Line out converter noise
    I'm having a problem with the LOC that I installed into the factory stereo. Regardless of which speaker I connect the LOC to I get the same problem...when I have the door open everything is ok, however, when I have the door closed, it seems like a signal gets sent to the sub amp and it produces...
  8. Peggle
    LOC help
    Hello all, Sorry about being nooby (as this is my first system) but I'm in a bit of a spot... I have a strick budget so I can't get a new head unit because I own a mustang with a shaker 500 system and the wiring harness is over $100! This leaves me with my stock radio. I want to add 2 12"...
  9. P
    I need advice with my LOC install!
    I have a 2008 civic si that I installed an amp and 1 12" in about a year and a half ago. I kept the factory radio so I installed a cheap LOC with a remote turn on in the rear deck where the factory sub used to be. I have a power acoustik ps2-800 mounted under the rear deck. The first sub I...
