Do I need a LOC?
That works too.
I ALWAYS run new wire and leave the factory wire and connectors intact, which makes it easy to put the OEM stuff back in should you sell the car.
This is the OFC copper wire I run to components and coaxial speakers.
This is a good buy on OFC copper wire for the subs.
If you want to keep all the infotainment and steering wheel functions with the new head unit, you'll need some specialized harnesses from Meastro and iDatalink. Check with Crutchfield as to what you'll need, then check with me if you decide to go this route. I have a couple of items like the Meastro RR left over from my daughter's build, and could save you a good amount of money since they are vehicle-specific.
As for speakers, also have a pair of the Mobile ES 6x9 coaxials from that build (normally $275 to $350 a pair) that I'd drop for $200.00.
The front components would be the Sony Mobile ES-162ES - they'll set you back around $350- $400 a pair, but this particular Sony lineup is superb-sounding gear.
Sony Mobile ES XS-162ES
https://www.ebay.com/itm/306890820772?_skw=sony+xs-162es&epid=13047066760&itmmeta=01KR930Y9HBYMX1JGYQ65P355Q&hash=item47741e4ca4:g:ktEAAeSwA7pp5S89&itmprp=enc:AQALAAAA0GfYFPkwiKCW4ZNSs2u11xDX3zUUqw7Um/SsEmgVJhaHsqAwOv9ExACS4NZjA9ZJ5k3twxmhgaGoVDFoxxnui9M8by5RWBZAHOvnFL1Hb7kpDUa9BpbcYRqjOtUqiC6qn8QszX5aQLaHNxvrRzQNkDSZMy5ZhKcK3pxxjbqVUQSqNxeCrWpFpnngL5g5kQyeofpZ7X1QpW0hy8SfiKpWY+t4rlGBDKRZDFGMy9bNMN+Fs+gsUMcPNr7U7h3eTsEATj9PNe1LbQwkKEV5sgj0kZA=|tkp:Bk9SR5Dlg6PCZw
Check with @Sakekura for reference, he purchased the 6.5" coaxials we didn't use as we went with the components up front instead.
As for an amplifier, a couple of options.
The Recoil RED1800.5 is the budget king in 5-channel amps, and it's a decent amplifier. 140 x 4 and 1280 watts x 1 at 1 ohm, hard to beat for the money.
https://www.amazon.com/dp/B0BZ8882ZD/?tag=caraudiocom-20
A step up (and worth the extra) would be the CT Sounds CT-1500.5 D, with a first-time or email sign-up, 11% off, and since I was going there for a pair of loaded 12's, a contender for sure. $239.00
And this to complement, same 11% discount, $339.00:
At $1180.00 so far, that leaves $1320.00 left for the head unit, adapters and wiring, sound deadening, and other installation items needed.
This would be a pretty significant system and still fits both the budget and the stock electrical system.
Crutchfield has some good deals on Kenwood digital multimedia and CD/DVD head units, and so does eBay. Just depends on whether or not you play CDs/DVDs or not.
Gotcha! How much of a pain was it to run speaker wire from the trunk into the front door panels and the dash corners?
It's not difficult at all, just takes a little time and patience to remove the various plastic trim covers and pull up the carpet, which you will want to do anyway, so you can apply sound-deadening products underneath.
I'd grab a couple (2) of these 36 sq ft packs while you can get a 10% off first-time purchase discount.
Hard to beat the price for regular 80ml CLD, this stuff is almost 40% off the nearest competitor that I can think of for 36 sq ft, and no shipping charges either!
72 sq ft should be about right to do all the interior of the car and doors.
Mpbanshee
Mpbanshee
Indiana
