HELP. And getting to hot.
  • 5
ryanpowell41
michigan
Alright goes I’m pretty sure I know the problem but here’s my situation. I had 2 alpine type r 10s that are dual 4ohm 500rms max.
I was running them with a ct sounds 1000rms amp 1 channel.
I recently upgraded to 2 12” ct sounds tropo xl.l that are 1000rms per sub. I totally understand I’m running half the rms to each sub. They are wired to 1ohm but my amp never got hot before and now I realized it’s pretty warm. It’s not like on fire but it’s warm and it’s NEVER gotten warm before. Pretty sure my problem is I just need a bigger amp but curious what you guys would think.
It sounds like you are asking your amp to work hard, and it's heat dissipation system is working.
Use it and jam out. If and when you upgrade to a more powerful amp, the new one would probably run a little bit cooler.. being built to dissipate even more heat.
Yeah I’m literally running half the power the subs are rated for. So tomorrow I will be ordering the cat sounds 2000.1D amp.
If you run your stereo loud...the amp is gonna get warm...that's normal as long as it's not going into thermal protection you should be good
507
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
896
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
174
ryanpowell41
ryanpowell41
michigan
chillin
maylar
    Jun 2, 2024
    Jun 1, 2024
