Door install
BCotrell
Asking for feedback
2013 rx350 plotting install for door drivers
Metra adapters, mjm or solid customs from taco tunes? I like solid but at $120 for all four doors it’s more than I want to spend.reviews on metras is that they good for the rx
Butyl 80mm on inner door with egg crate foam aligned with speaker magnet
80mm butyl between adapter and door mount surface. May use butyl tape that operates like putty (seals)
Silicone baffles or foam baffles to seal between speaker and adapter and waterproof. Back of foams I’d cut out
Foam wave control strips around driver between driver and door panel
Thoughts? Must haves to keep it on the budget-smart side
Thanks
Asking for feedback
Thanks
It looks like you're planning a thorough installation for your 2013 RX350's door speakers! Let's address your questions and thoughts one by one.
### 1. **Adapters: Metra vs. Solid Customs**
- **Metra Adapters:** Generally, Metra adapters are known for their reliability and compatibility with a wide range of vehicles, including the RX350. They are often a good budget-friendly option and have received positive reviews from many users.
- **Solid Customs:** These are typically higher-quality and more robust but come at a premium price. If you're inclined toward quality and can stretch your budget, they’re a great choice. However, if you're looking to save, Metra could be the way to go.
### 2. **Butyl and Foam Usage**
- **Butyl on Inner Door:** Using 80mm butyl on the inner door with egg crate foam is a solid choice. This will help reduce vibrations and improve sound quality by minimizing road noise.
- **Butyl Between Adapter and Door:** This is a good practice as it helps create a seal and further dampens any vibrations. If you prefer, the butyl tape that operates like putty is also effective for sealing.
### 3. **Baffles**
- **Silicone Baffles vs. Foam Baffles:** Both options are good for waterproofing and sealing. Silicone baffles tend to provide a better seal against moisture, while foam baffles are generally easier to work with. If you cut out the back of the foam, ensure it’s still adequately sealing against moisture and dust.
### 4. **Wave Control Strips**
- **Foam Wave Control Strips:** Placing these around the driver between the driver and the door panel can help control unwanted sound waves and enhance audio quality. This is a good addition for a more refined sound.
### 5. **Budget Considerations**
- To keep costs down, prioritize the items that will have the most impact on sound quality and installation integrity, like the butyl and the baffles. The Metra adapters are a good way to save some money while still ensuring compatibility.
### Conclusion
Overall, it seems like you have a solid plan in place with a good focus on sound quality and moisture protection for your door speakers. If you're balancing quality and budget, using Metra adapters along with your planned butyl and foam installations should work well.
Please feel free to share more details or ask further questions! Other members of the community may also have valuable insights, so I'd encourage anyone with experience or advice to chime in!
BCotrell
BCotrell
irvine, ca
Jimi77
ThxOne
    Jun 27, 2026
ThxOne
    Jun 27, 2026
