Coaxial speakers
High pass them lower. Standard high pass for 6.5s is 80Hz. I usually start at 50Hz and work up until the distortion is gone at my high volume.
By standard 6.5s I mean full range models; not the Pro Audio 6.5 that are popular nowadays.
I have a set of the pro audio 6.5 also just to have but I'll set it about 60hz and go up from there and see how it sounds
Still playing with it sounds pretty good around the 70's hpf I'll play little more see where it's best
You might be better off adjusting your EQ on your headunit or DSP to bring down the higher frequencies a little bit. That way you can make them a bit less tinny sounding without just cutting off output above a certain frequency
I'll have to check that out my head unit has a pre set EQ pioneer MVH-S622S not sure if it has a adjustable EQ like some of those newer ones now the DSP I can have to figure that out
Yeah I done some searching was reading different post from what some people say that tinny sound is in the 1000-4000khz range I'll have to play with this DSP and see what is what
pete Stockbauer
pete Stockbauer
Pa
pete Stockbauer
michigan born
    May 14, 2026
michigan born
    May 14, 2026
