I'd add that Deaf Bonce parent company (Alphard Group) is a Russian Federation Company, personally, I prefer not to support Russian companies. The better option for any pro-style drivers that actually sound good while being very efficient would be Steven's Audio.Deaf Bonce Sylvester's if they fit. If they don't then go with Infinity Reference or Polk Audio two ways. Just my 2 cents. I've ran all of them. Mounting depth might be your issue. I've also owned a 94' Ranger.
Their midbass are superior to any of the Def Bonce which are essentially rebadged guitar cabinet midrange drivers, not midbass drivers, They have an fs of 110 hz, and a recommended crossover point of around 125 hz and an RMS rating of 150 watts . The Steven's are reasonable @ $88 each and they will actually play from 90 hz up (the DB start at around 125 hz) and the Steven's drivers have a thermal limit of 300 watts RMS, twice that of the DB drivers.
At the end of the day, for pro-style with sound quality (and gobs of volume) in mind, Steven's audio, hands down.
Available in 2 or 4 ohm variants.
MB6 Midbass Driver (ea)
View Spec Sheet Here: SA MB_6 Data sheet.pdf The MB6 is a hi-fidelity midbass driver with high sensitivity. Perfect for use in 2 way and 3-way systems, or with our HLCD for an incredible horn loaded audio system. With a low Fs and longer excursion, they produce midbass with impact and dynamics...
stevens.audio
