Whats the difference between Pioneer DEX-P99RS & Pioneer carrozzeria DEH-P01 Head units
masterblaster1
Hi, I was looking at a pioneer DEX-P99rs head unit,when I came across the Pioneer Carrozzeria DEH-P01 Head unit.When I look at both the head units. They both look pretty much identical except one says Carrozzeria on the outside.The other one just says Pioneer DEXP99RS on it Are they the exact same internals inside,and work the exact same and have the exact same sound quality. Thanks
Here you go. Here's a link where a guy compared them. Also, I hear Japan uses different radio freaquencies than we do.
Hi, Thanks for the link on some info on it. Sounds like the radio may be in Japan. And japan version came with a 6 channel amp, and I,m not sure if the set up menu was and is in Japan.That would be a big problem if it was , You would never be able to set it up properly if it had a Japanese set up.I wish I could get that clarified,Also I wish there was more on if the internals were exactly the same, and if someone owned them both,or had a chance to listen to them both to see if the sound quality was exactly the same with both of them.
To be honest, due to them coming from the same manufacturer, you may not notice a difference unless you played them side by side. Just like a Premier deck vs a standard Pioneer deck.
masterblaster1
masterblaster1
Manitoba
masterblaster1
