Box for single 12" Kicker CompQ
zoltman1991
Alright switching up to a single 12" CompQ.
I'm between several boxes but wanted general feedback about sizing and tuning.
-kicker specs say 1.75cuft - 3.25cuft, so boxes I'm looking at are within this range (after displacement).
I listen to primarily heavy-hitting EDM (no techno/house, more dubstep and liquid bass lines). Most of it generates higher bass lines, however I still want a good quality low-end. Right now, I have two 12 CompRs and I feel when I listen to bass with low freqs, it sounds bad.
Few questions before I post a few boxes I'm looking at:
-size: if I go lower or higher end of specs, what is the end result? Freq ranges, SPL v. SQ, output.
-frequency: if I go lower or higher ends of frequency, what is the end result? Most of the boxes are low 30s, however some are low 40s. Again, I listen to primarily EDM. Ultimately, I want to generate the best response curve with a ported box. I've tried sealed. It's nice, but I feel I compromise too much output so I want to stick with ported.
Here are a few contenders:
2020 Lexus ES350 correct?
If it was my car using a single 12 I'd use that ski-pass and do a 4th order. The loss of cone won't be as noticeable and it will be punchy with a sealed type low end extension. Plus output will be directed into the cabin for added output.
Tuning a 4th around 45-47hz should give you what you're after imo.
This ^^^^ was designed for less than optimal subs (DDX-10's) and the results floored the customer. Clean bass with a punchy response and good low end extension into the mid-upper 20's.
zoltman1991
zoltman1991
houston
shredder1
NorthFramingham
    Jun 30, 2026
