2011 Tuscon Limited - No sound after ZAP
If while testing you accidently touch two pins on a live circuit, we could end up frying a working amplifier. Another way to test is to get access to one of the speakers and do it there. That will also allow you to test the speaker's resistance.
Okay I'm not quite understanding then, I thought I was doing the same style of test with the probes as I did with connector A (only using ACV setting). The amplifier won't even be plugged in. Am I missing something?
My bad. For this test the amp will be activated. I wanted to test if the radio was sending audio but I do not see the audio input in the pinout. So testing at the speaker is the next step.
Should I just disconnect the connector and test the ports here:
The diagram I posted is for a 2017 model, nvm.
Where do I test at the speaker? Never opened a door panel before, unless the tweeter in the sail panel is fine.
Okay I ran an ACV test with the car off as well as running with the radio on.
Used the probes at the two-wire tweeter harness and on the backside of the tweeter when connected.
0 V steady.
0 V steady.
Ok just to clarify; amp fully connected, radio playing, volume at least 50%? 0 volts. Aside from the 3 connectors, are there others? I wonder where the audio signal goes into the amp.
Last test. Using the pinout, test each speaker's resistance on the harness side. If they are all around the same, then the amp may be the issue.
Amp was fully connected (there are 3 ports but only 2 connectors).
I assume the radio was playing (set it to a station at least) but I can run sound on aux input tomorrow.
1/4 volume or so.
I'll redo ACV test and then conduct resistance test before reporting back.
Thanks for your patience and help.
Right, fully connected, radio on >50% volume, or off, 0 V steady. Same results as yesterday.
Tested resistance on both tweeters and passenger side speaker, steady 3 k ohm for all, radio/car on or off.
What we want to measure is the speaker itself, no connector on it. The connector will give a wrong reading.
Alright, I can't get a steady resistance reading (even with stationary probes). It just hops around, car/radio on or off. Max was about 11 ohms. Not sure what it means.
Yes, any ambient noise will get the cone to vibrate causing resistance variation. The good thing is that it means the speakers are still good. So the amp is not sending power. When you tested before you got zero value regardless of radio volume. Tomorrow I will test my amp's speaker output with the volume on zero. I want to see if I get any kind of reading.
If I do get something then you should have as well.
Much appreciated, I'm getting the feeling the amp is toast. Excited to hear your results!
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
Hello, I just installed a Chinese Headunit and wondering for the Steering Wheel Controls if i need something else or if it should work.. On some...
rvgenomini
rvgenomini
oregon
rvgenomini
