2011 Tuscon Limited - No sound after ZAP
rvgenomini
31
oregon
I put my key in the ignition and turned half way to roll windows up. Heard a
ZAP.
No sound ever since. Radio unit still functions. Audio/sound fuses in panel
are good. Had battery drain issue (hopefully resolved with new battery the
other day).
One shop looked at the issue, said they found nothing.
Took to dealership, said they found nothing and quoted me $8600 to replace
radio unit.
Took to Car Toys, they said they can't diagnose a digital amplifier, removed
my amp to get model number so I can hunt a replacement.
So my question, will replacing my amp with another factory model be worth
my time and money, or are there other options?
Not at all, could well be the radio or the fuses. You said you heard a pop. What location did the sound come from? Did all the speakers stop working at once? Were fuses checked with a multimeter?
The pop sounded like it came from the speakers.
They all stopped putting sound out after the noise.
I don't know if any of the shops inspected the fuses with a multimeter, I did a visual inspection of the fuses from the panel on the underside of the dash.
The next step would be to check the power and accessory power at the amplifier. This pinout will help with wire identification.
Positive voltage for all three ports (1-3) in OFF and ON settings. The multimeter counts up from ~0 mv to 200 and then starts over, for everything.
I used the metal bolt on the attached car jack as my ground.
Does this suggest it's a radio unit issue?
No, this voltage comes straight from the battery through a fuse. It should be a solid 12v DC at all times. Test the amplifier fuse on both sides to see if you get the same results. Test Pin7, that should be the amplifier turn on.
Alright I'll take another look.
I'm using this multimeter, set to DCV:
Okay I was able to get steady 12V.
Ran each test twice.
OFF
1 - 12 V
2 - 12 V
3 - 12 V
7 - 0 V
ON
1 - 12 V
2 - 12 V
3 - 12 V
7 - 12 V
OFF
1 - 12 V
2 - 12 V
3 - 12 V
7 - 0 V
ON
1 - 12 V
2 - 12 V
3 - 12 V
7 - 12 V
Awesome, so the amp is getting power and being triggered. Next test is to see if the radio is sending audio. For that you set the multimeter to AC volts. On connector C Pin6 is positive Pin12 is negative for front left door speaker. Expose the copper of those wires for testing, it is safer than touching the pins. Turn on the radio and see if you get any reading. If that works, then the amp is good.
I'll have to get to it tomorrow.
Out of curiosity, what exactly is the risk with looking at connector C the same way? Exposing the wires will be a huge pain so I'd love to not do that if possible. Thanks.
If while testing you accidently touch two pins on a live circuit, we could end up frying a working amplifier. Another way to test is to get access to one of the speakers and do it there. That will also allow you to test the speaker's resistance.
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
Hello, I just installed a Chinese Headunit and wondering for the Steering Wheel Controls if i need something else or if it should work.. On some...
rvgenomini
rvgenomini
oregon
rvgenomini
