Taxed1
Has anyone ever seen this through their phone’s camera. The subs look almost out of phase but they have been triple checked. Even busted out the old 9 volt battery polarity tester. Both leads from the amp are the same exact length. All internal leads are the same length. Ohms out at 1 ohm so if one lead, either inside or outside, was wrong that would be a given. It is on a SIA-3500. I will be checking my other cars subs tomorrow with this same phone & I will update the post with my findings. Using the ***** eye there is no problem whatsoever but when recorded it almost looks out of phase. Could it be the dual aero ports causing weird things that cannot be seen with the ***** eye unless recorded or is the phone a piece of crap with processing going on.
It sounds perfectly fine.
