Winners only.
I will break it down for you, the laymen. It states that tubes are generated inside the hollow parts of bones and in these "tubes" run the nerves. These tubes run throughout the bone and allow the nerves to pass through them.
Jackass.
Ohhhh, you think the Haversian canals are like conduit installed down the middle of each bone, and the nerve fibers run in that conduit to a termination point?
OMFG, this gets funnier by the second. Holy shit do you have a childlike view of things.
Lemme ask this, then: Why does a simple fracture hurt if the haversian “canal” doesn’t get damaged in any way?
Let me dumb it down further for you.
Take a ball point pen. The outside is the bone. Inside is the tube that holds the ink (the nerves), this is the lamellae. Inside the lamellae is the ink (the nerves).
If you don't break the "canal" and you feel pain then it is most likely form the nerves in the surrounding skin/tissue.
Here you go ignoring shit again.
Ignoring WHAT? Your demands that you are right, even when you lost your own proof that shows you are wrong?
THROUGHOUT
If you don't break the "canal" and you feel pain then it is most likely form the nerves in the surrounding skin.
You just described the tube and the ink as “Inside” the body of the pen. Inside means “in”. It even starts with the word.
You just proved yourself wrong yet again.
Do you ever sit and just slap your own face?
THROUGHOUT
You are just going to keep arguing. Fine, fuck off. Hey look, you reached your goal. I no longer care to argue with you. I guess you can tell all your friends you won an internet prize for trolling someone until they walked away from your dumb *** argument.
Hey look, your leaving out shit. The ink is passing THROUGH the tube that is in the pen body. The ink does not touch the body of the pen.
No, I don't slap my face. Why would I, I am correct and you are a troll. I'd love to slap the taste out of your mouth though.
INSIDE A word YOU used to explain where nerves are, relative to bone.
Inside means IN. You disproved your thesis again. Too fekkin funny!
Where is the tube? INSIDE
Where are the nerves that you use the tube to represent? INSIDE
YOUR words, kid. You proved yourself wrong.
Again.
Priceless.
In would make it a part of the bone structure. It is not as it resides inside of another structure as it passes through the bone. I am sorry you don't get it. Blame your upbringing.
So the ink is only in the tube but not in the pen that the tube is in?
The tube is in the pen but the ink is outside?
Sorry kid, there is no backpedal or tap dance you could ever do to get out if this one.
You posted proof that you are wrong, then tried to post an analogy, but in your analogy you admit you are wrong.
It’s kind of pathetic, but still funny.
Like when you said nothing happened on January 6, 2021, then you complained about Ashley Babbitt being killed unfairly, after you claimed that the incidents that never happened were instigated by undercover Democrats.
You can’t keep your story straight if it meant saving your life.
You're both being retarded.
"You look like a fool Rob. Every time you post you show how stupid you are. Done!! Just move on. For the last god damn time. THROUGH NOT IN!!!
"Blood is supplied to mature compact bone through the Haversian canal. Haversian canals are formed when individual lamellae form concentric rings around larger longitudinal canals (approx. 50 µm in diameter) within the bone tissue. Haversian canals typically run parallel to the surface and along the long axis of the bone. The canals and the surrounding lamellae (8–15) are called a Haversian system or an osteon. A Haversian canal generally contains one or two capillaries and nerve fibers. The Haversian canals also surround nerve cells throughout the bone and communicate with osteocytes in lacunae (spaces within the dense bone matrix that contain the living bone cells) through canaliculi. This unique arrangement is conducive to the storage of mineral salt deposits that give bone tissue its strength".
You will argue out of ignorance. I encourage you to shut the **** up. You're stupid."
Oh, I see. Since the nerve is in the Haversian system, they cease to be inside the bone. Sort of like when I drive my car thru a tunnel, since I'm in my car, I'm not in a tunnel. Or when I'm in my bedroom, I'm not in my house. Or if I pull my car into my garage, I'm not in my garage until I exit the car. It's like the Russian nesting dolls, there can only be one doll inside any other doll even if you have a set of seven. Or my midbass driver isn't in my car, it's in my door. Probably the best example would be to use canals - so the water in the canal down the road, isn't in the city or state, because it's in the canal. Or to use a biological example, there is no oxygen (or CO2) in my body because it's in my lungs (or blood). Makes sense.
And there are pipes in my house because the pipes are not inside my walls.
There is no blood in your body because it’s in your veins, capillaries, etc.
There is no Coca Cola in my refrigerator because it is inside a can in the refrigerator.
No water in my house because it’s inside the water heater.
Yet Trump did not cause the insurrection when he directly told his followers to go to the Capital and “fight like hell” ( his actual words), but Biden told Mexicans to cross the border illegally en masse, even though he never addressed them.
How the hell did he even get a job as a pizza boy? Hire the mentally handicapped program?
Nice try. You posted the proof that nerves are IN bones.
THROUGHOUT as a matter of fact, based on what you just posted.
THROUGHOUT means IN.
You literally disproved your own thesis. Hahahahahaha.
Maybe put your obsession with male genitals on hold when you try to argue. It might help reduce all of the failures you keep making.
You're not getting it. It's like when you drive your car through a tunnel, you're not in the tunnel, your car is in the tunnel, your clothes are inside the car and you're inside your clothes. You are 2 degrees removed from being inside the tunnel. Your problem is you're too analytical. This isn't Quantum Mechanics, this is the English language and in the English language nothing can be in 2 places at once.
As an English major, I have to say this is completely consistent with how "in" is used throughout the language. If A resides in X and X resides inside Y, we would never say A resides in Y. In Quantum Mechanics "A" can reside in two places, but not in the English language. For example, if I ask you where is your phone, you don't say "in my pocket." You would say, "My phone is in it's case." Think about it, if somebody calls you and asks where you are, you've never answered "in my house" or "in my bedroom." You'd say, "I'm in my new suit" or "I'm in my pajamas."
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
