bulldozer00
hello everyone, I recently installed a used amplifier in my car, so it is not new. Of course, I put the power cables on one side, and the speaker cables and RCA cables on the other side. I put the ground wire under the bracket from the rear bench of the vehicle, and sanded it well, at first everything worked perfectly, and I had no problems with signal interruption. After 5 - 6 days, once while driving, I noticed that the speakers suddenly stopped for a moment and then started working again, I was testing the bass, so I thought it was because of that and just kept going, the second day when I was driving, the speakers were just stopped working, when I start the car or the head unit, I hear only crackling sound at the beginning and then nothing. At first, I thought of the fuses because the contacts on them were bad, I went to grind them and put the fuses back and it worked. The next morning, I start the car and the same thing again, there is a crackling noise at the start. I can't solve this problem at all. By the way, I put in new fuses, checked the ground wire, and sanded that part again, but nothing. I watched some tutorials on youtube and even measured some parameters with a multimeter and everything seemed to be fine. The only thing I haven't tried out of everything is to change the position of the ground wire, I'm not sure that could be the problem, what do you think?
(I checked the speakers on another source, and they are working normally)
