(Wiring) JL audio C5-525-XO : Component issue with tweeter.
Up_si_down
Oxford
JL AUDIO C5-525-XL
Sorry in advance don’t know all technical terms. Issue with the tweeter.: See that little plug thing that lets you choose what level to have. It works fine for the main speaker - I can choose anything. however for the tweeter I can only get it to work with +2 which isn’t ideal. I only discovered this is I had intermittent sound cutting out which I couldn’t figure out. The white block far right (capacitor?) seems a bit loose but don’t fancy dismantling any more - either way fiddling with tiny movements on that didn’t seem to make any difference. Any ideas?
Thanks so much. Simon.
White blocks are resistors. They control the output level of the drivers. If one were broken or had a bad solder connection, that would explain the issue you're having.
You may be able to locate another set of Xovers like from CDT Audio that will give you some options with tweeter settings and working properly. There should be a nice selection for the Labor Day Sale
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
747
262
272
Up_si_down
Up_si_down
Oxford
    May 8, 2024
    May 8, 2024
