The truck is well sound deadening
Using amplifiers that do rated power with decent specs, good S/N and good damping factor. Also and the amp power is rated over RMS power for the speakers to have enough headroom.
Headunit is the JVC kwz1000W
Tuning will be done with DSP and RTA readings.
Going with a 3 way setup
option 1 lets say tweeters massive ct 2 tweeters SB acoustics SB17 6.5 inch CT sounds Meso 3.5 midrange
cost for option 1 Around $297
option 2 focal PS165f3 Flax 3 way set
option 2 cost 899.99
Option 3 morel hybrid 63 3 way set
cost for option 3 $1430
Bottom Line if set up correctly are high prices speakers worth it?
Do $2000 speakers sound only a small amount better than say a set of $1000 set, but not worth the cost difference?
Is a $1000 set only a small amount better than a $500 set?
For a 3 way setup what would you say is the magic cost to value to go with , tweeter, 3 inch, 6.5 inch, Brand and model recommended.
