Power Wire Grounding out after fuse
Fuses in the amp prevent the amp from causing a fire. Fuses in power wires prevent the power wire from causing a fire. It's as simple as ohm's law. Current is based on supply voltage and total resistance. It's a law, not a theorem. If an amp draws enough current to cause damage, it's because the amp has an internal short, meaning lower resistance. Your battery can't randomly defy ohm's law and throw more current at the amp just because there is a new parallel load (the short) in the circuit.
That is mostly correct, however there are factors outside of a battery that can cause current spikes...like the alternator. This is why the computer in a newer vehicle will detect overcurrent and prevent its self from frying. This happened to me in a new alt install where the diodes were failing at high temps. Car ran great, 20 minutes into the drive it would start randomly going dead and then springing back to life.
Please specify what's not correct. I used "battery" as a generic term for supply voltage. My sentiment stands. A shorted cable doesn't cause a current surge downstream of the short.
I never said shorted cable, I asked if the fuse in the amp would protect the amp. You said it's there to prevent the amp from causing a fire. However, that fuse should also pull duty protecting the amp in the event of overcurrent.
I thought I was being helpful with a descriptive answer. Apparently i was wrong. The short answer to your question is NO.
I must not be making myself clear enough...
THE FUSE IN THE AMP DOES NOT PROTECT THE AMP. THE ONLY THING THAT BLOWS THE FUSE IN THE AMP IS AN INTERNAL ISSUE. IF THAT FUSE BLOWS, IT'S BECAUSE THE AMP HAS AN INTERNAL ISSUE. THE FUSE IS THERE TO PREVENT THAT INTERNAL ISSUE FROM STARTING A FIRE.
Again, refer to ohm's law. Overcurrent can't defy ohm's law. It's really that simple. The fuse in the amp doesn't protect internal issues. It prevents the amp from causing a fire should an internal issue occur for whatever reason.
So it is some sort of fancy one way fuse then? If the fuse blows to stop power from exiting a device, wouldn't blowing said fuse also stop power from entering the device?
The fuse blows because there is excessive current going through it. The current rush is between the battery and the short to ground, because ground is the opposite polarity. When a direct short to ground occurs, there is higher current between the supply positive and negative. In the context of your question, "entering the device" means going to ground. Electrons move between positive and negative. A short causes a direct path between the two, meaning less resistance, and therefore higher current, which results in a blown fuse.
I'm not going to get into the conventional vs. electron flow argument, if that's what you're alluding to. I can't tell if you're arguing to argue or genuinely confused. I'm willing to explain things as much as I can, but not if you want to make snide remarks such as "fancy one way fuse".
Think I'm wrong? Test it. Do some research. Do some experiments. By all means, please record it on video. If you correctly connect a brand new amp to positive and negative of a battery, short the positive to negative in between the power supply and the amp, and the amp is damaged because of the short, I'll buy that damaged amp from you for whatever you paid for it. I'm putting my money where my mouth is. Or how about I buy a brand new amp and run the same experiment: if the amp isn't damaged you pay me what I bought it for. We can put something in writing before we go through with either method. This would be the best way to put the issue to rest.
Think of it like traffic heading through a stoplight. The stoplight lets a limited amount of traffic through. Then, a detour opens up that lets an unlimited amount of vehicles through to the same destination. The traffic between the stoplight and the detour come from the same place, but traffic through the detour doesn't affect traffic through the stoplight.
A fuse is to stop power from ENTERING a device, NOT "exiting a device". A fuse is to protect both the equipment as well as the power source from damage or fire. Nothing more. The same as your breakers in your house electric panel. There are no "exit fuses". There are no "1 way fuses".
If there is a short inside the amp then there is a fault in the amp. The internal fuse is simply reacting to a short already inside the amp ripping its way through the fets and destroying them.
Essentially, saying that the amp's fuse protects the amp from damage is like saying a car's airbag prevents an accident.
They call them "diodes" :)
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
901
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Jersey2816
Jersey2816
MO
RobGMN
kanihoncho
    Apr 28, 2024
kanihoncho
    Apr 28, 2024
