Lci2 or Kicker Kxa??
Assuming the amp inputs can indeed take the speaker level okay, I say try the amplifier first and see how it works out, no sense in buying extra stuff if the amp is supposedly capable. Otherwise the AudioControl converter would probably work fine for the application if needed, but I'd try just the amp first to keep it simple.
That is what I was thinking, I just didn't know if anyone had used it before maybe it didn't work like advertised but hopefully it does. Thanks for thebreply
Years ago there would have probably been guys with hands on experience to share, but seems the forums are pretty dead these days so it might be a slim chance someone running that specific amp like that on here; unfortunately you might be the one that has to test it out and see if it works properly. You’d think a modern amp should run high level input no problem though.
I have noticed forums are pretty dead now a days, once I test it out I will let you know how it goes
Chalo_209
Chalo_209
Kingsport tn
Chalo_209
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
