4/0 cable
33001
Google says 4/0 can carry 310 amps. Although, I don't trust those numbers. IIRC, 1/0 oversized car audio OFC wire is rated for 300A. So, I'd say reasonably, it should be good for 500-600ish amps.
10k watts, let's say 70% efficiency. 10,000/.7= ~14,280A draw on electrical system. 500A safe bet per run, and you should be good with 3 runs. Although, if you know the current rating from the manufacturer, I could do some better math.
I ran 4 runs of Sky High 2/0 OFC when I had quad alts, 32 batteries, and four Vital Power 7k's @.5 nominal. My voltage drop was minimal. That being said, You would probably be ok with 2 runs. I definitely recommend dedicated ground runs as well. That's a lot of current to run through the vehicle body.
Looking at knukonceptz they claim over 600A @ 20 ft. I was gonna double that to stay safe. I don't crank it all the time but for when I would like to know I have a good flow of electrons
No make or model number on it? Do you have an exact picture of the rear and all its glory?
528
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
HondaCRV03
HondaCRV03
Miami, FL
adulbrich
    Apr 28, 2024
    Apr 28, 2024
