How can I repair crack on actual speaker?
  • 5
Terrum
I accidentally cracked the speaker of my JL 15". It still works, but I am afraid of increasing the volume in case the crack gets worse.
What would be the best cause of action to repair this? If I should glue it, what would be the best kind of glue to use? Epoxy, silicone, any other suggestions? Opinions on coffee filters?
I did try search but most results seem to be about gluing the rubber/surrounds. But I apologise if this post is already answered.
Many thanks for any help!
CA glue!
Elmers glue and a coffee filter is hilarious.
Actually seems reasonable for say a 50W paper cone on some old bookshelfs or a guitar cab type speaker.
The crack doesn't appear deep enough for it to show on the back side.
Which means that's not the cone but just some cosmetic bit. I like Amazing Goop brand glue for a lot of speaker repairs. Shoe Goop comes in black and may look slightly better to just smear a little on there to keep that crack from spreading. Honestly you could probably just stick some gorilla tape on there and be fine.
I wouldn’t spend on something very expensive. You could likely try and even the crack our, tape it off and use some super glue since I doubt it’s going to effect anything.
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
4K
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
I was tempted to send an offer, but felt the 100 was fair for it since it was like new still. You still did good on it though.
Terrum
Terrum
United Kingdom
Bobbytwonames
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
