Multiple subwoofer wiring
Dafaseles
CarAudio.com Exclusive
402
192
510
So yeah, easy question, I'm pretty sure I'm right, but left alone with my thoughts, I can think myself out of the right answer for some reason.
So I have 4 dual 1 ohm subs and 2 Sundown Salt 4 amplifiers. I'm going to run 2 subs each amp. If I wire the subs in the fashion as seen in the picture, I'll get a final load of 1 ohm correct? I'm just looking for validation that I've been correct or proof that I am, in fact, a dumb *ss. Thanks in advance
Yeah, I got the info off 12 volt, it was just a little confusing because of it only being for a single input, so I looked at just 1 1ohm dvc wired to 2 ohm. That's where I got my drawing.
So pretty much positive and negative wired together from each coil, and then one positive and negative from each coil into the amp?
Series parallel.
Wire each sub to 2 ohms. Then wire each pair to one ohm. Or if you strap them, wire all 4 subs to .5 ohm and then series wire all of them to get 2 ohms.
Yeah, I guess the simplest way to put my question was is that picture going to yield me 2 ohms each sub and wiring each sub into it's own positive and negative slots into the amp, would the amp then see 1 ohm. I was just going to have 4 separate speaker terminals on the box
Yes.
26855
Oops.. I f'ed up.
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
Dafaseles
Dafaseles
marc2112
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
