Sundown 8k SFB @ 2.67 ohms?
that's what I was thinking if I turn the game down low enough the signal will be cleaner and won't be as much juice and give me a room to upgrade I've already got the 320 amp mech man alternator installed and going to put at least 40 amp hours worth of lithium power in the back if not eating so I believe my electrical is good and I'm running the fattest wires I can fit.
I'm running a Mechman 320, AGM, and 1/0 big three on a Sundown SFB3k. My current doesn't drop below 13 on heavy bass songs. I'm running 4-8's though. You will probably need the lithium with the 8K though.
I understand. I just bought a Sundown SFB3K. I was just curious if you were going to ridicule people for buying Chinese amps like you do the people who buy Chinese subs.
I don't see anything wrong with sfb series because sundown backs them up and lots of people are happy with them. I'm intentionally over buying so I can run it at 2.67 ohms which will make it not work very hard at all and stay cooler.
Like I said in your last post. That amps power numbers on paper and on music are completely different things. You aren't going to see 4500 watts on music.
Get the 8k. Set gain with multimeter. You have a clip indicator on the knob so clipping wont be an issue.
Sounds good to me I was rereading that myself that's going to be the route I take. I'll wait till the end of the month to see if the price is dropped that will give me time to get all of my box building wiring fabrication and sound insulation done.
Thanks again
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
5K
258
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
Kybasshead75
CarAudio.com Exclusive
Kybasshead75
Ky
Kybasshead75
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
