Win isd peaky response, error on my part?
jlund10
US
designing a box for a crossfire c7 10" plan on using the recommended 1.5 cf volume and tuning to 35 hz.
when i modeled the sub i noticed its ridiculously peaky unless i lower the volume to like 0.8 cf which is insanely low for a ported 10
25029
25030
Where did i f up? could a small mistake in the parameters be the cause?
You can't take winisd too seriously, and sometimes you can't take some woofer's t/s too seriously. Don't depend on that program for it's DB response. It can give you an idea of a rolloff, but I wouldn't worry about that peak too much.
thanks probably just gonna go with the manuals recomendation
Winisd is not accurate below 50hz because it cannot calculate vehicle transfer function aka cabin gain. Use bass box pro 6 instead. Its not a free program however.
Winisd is more for home theatre applications where transfer function is minimal.
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
jlund10
jlund10
US
THATpurpleKUSH
    May 19, 2024
    May 19, 2024
