Braided wire connecting speaker to enclosure tore apart
  • 2
Gosu_ryu
I tried soldering it back together but it keeps coming undone, so I over passed the natural terminal hookup and just spliced 16 guage wire to connect the pos speaker side to the enclosure but I am getting a rattling sound now as if the speaker is not secured correctly.
Is the purpose of the braided electrical wire to secure the speaker down? Am I wrong for bypassing the terminal altogether with the 16 guage wire?
Are you talking about the tinsel leads on the subwoofer?
There are positive and negative terminals within the enclosure to the actual subwoofer speaker within the enclosure. The braided wire ( I'm wondering why braided wire is even used in the first place) have become torn apart from the woofer being played at a high level
Post a picture.
In the picture, the right side is still connected to the terminal, the left side is bypassed with regular wire, I'm wondering if the loose 16 guage wire is being vibrated by the woofer enough to cause the rattle
Yes. That is a tinsel lead. Solder the wire straight and add some heat shrink, then secure it to the terminal to keep it from smacking the cone. They break from over excursion or clipping.
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
271
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
782
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
797
Gosu_ryu
Gosu_ryu
Massachusetts
Gosu_ryu
