installation - voltage problem - any help would be really appreciated
Scott1970
Hi, I just purchased a travel trailer with a cassette deck from the 80s. I went and bought a Pioneer DEH-S4220BT and proceeded to try and install it. I wired it up the way I thought it should be, but it wouldn't turn on even after pressing the microprocessor reset. Then I discovered that there was 17.4 volts across the power and ground.
I had both the yellow and red attached to power.
Disconnected there's 13.3 volts, red only 13.3 volts... yellow only 17.4 volts and all the lights in the trailer are brighter.
I'm obviously not doing this properly. Any help would be very much appreciated. Thanks in advance,
Scott
So the yellow is not going to be your memory. If it had a cassette deck than it would most like be something else.so what you could do is connect the red wire to both the red and yellow on the hu to make sure it still works. I'm hoping it didn't fry something with the extra power. If you have a model of the trailer than it would help to look up the wiring diagram.
So the new radio is stepping up your voltage from 13.3 to 17.4 ?
correct, it's an old trailer, I took out the old cassette deck and attempted to install brand new technology
the red is supposed to go to ignition and the yellow to constant power, the hot and ground are 13.3v on their own and then the mutimeter reads 17.4v when the yellow is connected
I have lots of old cassette decks that have memory wire ...
I think yellow is constant power and red switched ignition, I originally assumed the red and yellow should both be connected to power (as there is no ignition)
It's a 1986 Bigfoot trailer, don't have a wiring diagram...I used the power and ground from the previous deck, which seemed to work fine
You should check the chassis batteries, make sure they are all 12v marine and wired parallel. Anything above 13.8v is abnormal. If batteries are ok then I suspect your power inverter is on its way out. There is no way to get higher voltage by connecting two separate 12v wires together. Even 13.3v engine/generator off is not right.
I was sorta thinking a power inverter or something ... if the old cassette deck works and you still have it ..you could try rehooking it up and taking voltage measurements
so I did some more troubleshooting and now believe it is an inverter problem (not mis-wiring the deck)
when running on battery only it's a consistent 13.5 volts, either with or without the deck
when plugged into the house power (120v) it's 13.5v without the deck and 18v when it's wired up
the old Realistic brand cassette deck gives the same result but seems to work fine with the 18v
thank you so much for your comments and ideas that helped me figure it out, I really do appreciate it,
Scott
I am thinking of adding 2 OM-1 output and 1 VM-1 meters in my 08 jeep wrangler. Anyone here use them and do you like them? Also mounting them is...
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
Scott1970
Scott1970
Vancouver
Scott1970
    May 24, 2024
