how big port area should i have?
Hi
i have Digital design 818d D1 and my box will be 200L or 7 Cft3
i am thinking to get 112sq" slotted port area but is that too much or too less. I am running that subwoofer in 6kw max output, most of time it will be 2-4kw rms
Offhand I'd venture a guess and say it should suffice, it is 16in^ft3 of port after all. U can always model it on your power, in your planned airspace for more accurate predictions.
can you help me with this
16in^ft3 what does this mean? can you translate it to cm2
i have no idea, how big that is
Thank you and i respect you :)
is this enough?
You initially listed 112in2 of port for 7ft3 net... that is 16in2 per ft3.
96in2 in 7ft3 of net volume comes to around 13.7in2 per ft3.
If I was looking for sufficient port I'd model it, but if that's not possible... I'd say offhand again the 112in2 should work for a higher powered 18 in my exp.
The site recommends 5-6ft3 net, if you downsize the net volume a touch that 96in2 of port will be 16in2 per foot in 6ft3 net... this is really not the way to do this but as your planning to overpower/push it at times. I'd stay within volume recommendations and possibly undersize volume a touch if it was me.
Basshead107656
Basshead107656
Finland
shredder2
