I want to increase the shaking in my Car.
JustinKG
I have a Kia Sportage 2008 EX. I just put PRV door speakers and a Scar audio Ported Box with Kenwood Speaker. First time build. I get great Bass to the point where my side mirrors and the inside of my car shakes. There is a song by Travis Scott called "Don't play" and it doesn't hit hard as I want it. I don't know if its the bass but there is a rumbling in the track that should shake the car but doesn't. What do I have to get to make that type of bass or treble (not sure what it is, you have to listen to the song) shake the car?
I always felt that the car shake was an unwanted effect of loud bass. Anyways, there's going to be resonant frequencies in each of the car parts. Start off doing a sweep. You'll notice that there's a lot of variation within the same car. If you're getting resonance at high bass frequencies then you can always sound deaden those surfaces to get a lower tone. If your goal is only to affect the mirrors then go hz by hz until you do and figure out if that frequency is acceptable or if you want to lower it, but I don't know why you'd want to not be able to see behind you while driving.
Ok. I have a Kenwood DMX4707S 6.8 and it has a equalizer I'm trying to learn. I didn't install this stuff myself because I'm a noob but my friend's dad did. What do you mean "unable to see the behind" The 12 in woofer doesn't block my vision. And the shaking isn't to the point where I can't see a thing. Everything is fine. I just want other sounds in the car to be louder.
If you want it to be louder I'd suggest making sure that your amp is level matched to your subwoofer as a first step to get the most out of your equipment. The description of your amp is important, as is your subwoofer's model number.
I'll take a pic and come back lol. i believe they are both DS18s.
if you just got a random premade box, your sub is not hitting the low frequencies enough. You might wanna fork out money for a custom made ported box tuned to the low 30-34hz range. You might also just save up and get two beefier subs and an amp while you are at it. One thing that saves you money in the car audio long term rabbit hole.... when you upgrade.... UPGRADE. Dont do small additions here and there, do it big... You actually save money from being happy the first time vs not being satisfied and constantly wasting money buying and selling small increments that dont make that big of a difference.
there's a whole sub culture dedicated to bass so loud its rearranging people's internal organs, its not really enjoying music anymore its more like a life and death thrill seeking experience that never lasts long since your body gets acclimated to the SPL. Its also destructive financially and makes your vehicle useless but people do achieve inner happiness.
True, I just felt like that was ultimately for the purpose of noise (volume), not shaking a vehicle to death. Like don't people sound deaden strategically for SPL competitions to increase their numbers? I figured they wouldn't do that if they wanted the highest amount of chassis flex.
Id get a min of 4.0cft enclosure @30-34htz with approx 3k rms on a decent pair of 10s or 12s (1k rms min ea.)and the supply to back it up.
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
104
A set of rounds in all of the doors, not the front or the front and the rears, with the dash speakers, no mention of the rear doors, didn't...
305
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
You can add a passive x-over between the HK harness and Logic sub. Just know that an inline passive will also affect the HK sub's frequency curve...
516
I just had the normal muscle stiffness in the neck and back when you get impacted hard. I wasn’t going to lawyer up until my insurance company and...
21
64
JustinKG
JustinKG
United States
shredder2
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
