HOW MANY WATTS PER CHANNEL??
Maro
How many watts per channel and how many channel amp do I need to power a 3 way system?Audison Voce AV K6-125 RMS
+ Audison Voce AV 3.0 -
Power Handling
100 W Peak Power
I have a passive sub and an amp for it.
Suggestions for amps with dsp welcome.
Thanks
Voce AV K6 is a 2 way component set from my Googling. So a two channel amp when using the passive crossovers. If you were to run active crossovers a 4 channel amp.
That would depend on how many sets of component speakers you are installing. One channel for each set. The specs. call for 125 RMS Nominal power for the components. The nominal power for the Audison Voce AV 3.0 is 100 RMS. I would look for an amplifier that has a max of 100 RMS per channel. Some other audiophiles may suggest a higher maximum output for your amplifier. I'll leave it up to the more experienced folks to make suggestions for amps with DSP.
id just run the AV K6 and this bridged...
ditch the xtra mid
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
Maro
Maro
Warrenpoint
nauc
