Wiring 2 4ohm Dvc subs in seperate boxes to 4ohms.
What would happen if I connected both sub boxes to the 2 positive and negative terminals on the amp while the subs are wired at 2 ohms? Would the amp still be getting 2 ohm load from both woofers?
Yes.
I used to run two sep boxes for subs in the Acura Integras and 240sx to have room for amps in middle.Sounded just fine. Hey. If one goes bad.. at least the other is in a different chamber and you can still wire it up and have some bass that does just fine/sounds decent and retune
How did you wire it? I know how to properly do it but that’s with a box for 2 subs. Positive to negative on both subs and do I run the remaining positive and negative to the positive and negative terminals and run a wire from box to box?
Just Follow the wiring Diagram above.. One Poss Connection and Negative connection from Box to box and to the amplifier. Pretty simple,
Is this possible? Not going to try it just curious if it would work
Yes you can do a 2 ohm load on these subs, but you will only be wiring up 1 coil per sub and you will only be able to put 1/2 the RMS wattage value on the subs.If they are 500 rms for both coils wired up and you oly use one coil per sub. you will only place 250 rms per sub. Ive burnt one coil out on a DVC sub and have wired down to 1 coil and ran at 1/2 the power to have some Bass till I had enough funds to replace or buy new sub/subs.
What would happen if I connected both boxes to the amp while the subs are wired to 2 ohms?
As long as your amplifier is 2 ohm stable bridged in Mono you shouldnt have any issues.You can run 2 ohm Stereo mode also/ Full range- dont expect to hit some serious lows in stereo mode of course
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
357
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
310
386
Josh49
Josh49
Ontario, Canada
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
