New Here.. I Need Help With Rewiring My System
Thanks.. looking on Amazon for one right now as we speak
Like you already found out, get a good ground to that amp. 0 gauge is way too thick of a cable and hard to work with. I would get a 4 awg kit instead. Make sure it says 4 AWG and not 4 gauge. It will be anywhere $40-$75. Connect straight to battery with the kit's fuse 1 foot or less from the battery positive post. Positive to red post and Negative to black post of the battery. With the extra 4 awg cable, wire the engine with the body of the car. The strut/shock tower will be the best spot. Remove one nut that holds the strut in place and scrape the paint off until you reach clean metal. Crimp a terminal onto the cable tip and place into the tower bolt, washer on top of that, then the nut on top of that, tighten. Now do the same with a bolt on the engine. It may be hard to find one but is important. This will make sure that 100% of the power reaches your battery. This pic is the best I could find. Red is the wire and tips are bolts.
Like you already found out, get a good ground to that amp. 0 gauge is way too thick of a cable and hard to work with. I would get a 4 awg kit instead. Make sure it says 4 AWG and not 4 gauge. It will be anywhere $40-$75. Connect straight to battery with the kit's fuse 1 foot or less from the battery positive post. Positive to red post and Negative to black post of the battery. With the extra 4 awg cable, wire the engine with the body of the car. The strut/shock tower will be the best spot. Remove one nut that holds the strut in place and scrape the paint off until you reach clean metal. Crimp a terminal onto the cable tip and place into the tower bolt, washer on top of that, then the nut on top of that, tighten. Now do the same with a bolt on the engine. It may be hard to find one but is important. This will make sure that 100% of the power reaches your battery. This pic is the best I could find. Red is the wire and tips are bolts.View attachment 21335
The type of car I have doesn't have a battery under the hood it is in the trunk. Instructions still the same? I stand corrected also. I currently have 4gauge wires not 0.
PurpleHaze13
PurpleHaze13
Charlotte, NC
