Something that can push two 1000 watt rms @ 2 ohm subs that sounds and at a good price just not something like 300 to 500 dollars reallyWhat's considered budget friendly? What exactly is your budget? Could get this fairly cheap https://soundqubed.com/product/s1-1250/
150 bucks for a 1200rms amp is def a nice deal.
You're 1/2 right. He has 2 wiring options which is 1/2 ohm or 2 ohms, def not 1 ohm.So you can wire them up at either 1 ohm or 8 ohm and then depending on your amp , you can either wire them in series to see a 4 ohm or two ohm load.
would recommend a Phoenix Gold RX1100.1 amp as it does 888rms at 2 ohms according to the certificate supplied during testing so that is close to 1000 watts, not that you would notice the difference if you had the subwoofers in a box and tried them out using different amps.
My 2c worth. I use one so I am vouching for them! :fro:
Yeah but i wanna run two subs and i think they cost too muchSo you can wire them up at either 1 ohm or 8 ohm and then depending on your amp , you can either wire them in series to see a 4 ohm or two ohm load.
