2 dvc sub wiring help
Chris Caperton
Ok car audio gurus I need some help asap! I need some help understanding how to wire my setup. Here is what i have:
2 Sundown SA10-2 ohm dvc
1 RF T1500.1
My question is: If my box has 2 terminals (1 for each sub), can I wire each sub to 2 ohms to each terminal and then to the amp or would I be changing the ohms into the amp by doing that? Its a mono amp although has 2 pos and 2 neg speaker inputs.
Everything I can find only shows how to hook them up by drilling through the center divider and then a single line into the amp but my box will not allow this based on its design.
Please help!!!
Pictures for reference would also be nice. I'm an idiot with this stuff.
If there dvc shouldn't the box have 8 terminals?  Each coil has a + and - for total of 8 connections.   You might have to unscrew the subs and check the wireing in side.
Once you find out how they are inside the box,  heres what you need to do.
Correct.
Dragonsyph - you are correct that there are 8 terminals total on the subs. I was referring to the speaker output terminals on the box itself. The subs have not been installed yet. Everything is brand new.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Chris Caperton
Chris Caperton
C-LocJiggleNuts
pfft
    May 1, 2024
pfft
    May 1, 2024
