New to car audio and can use some advice
randpost
So I have been working on upgrading my car audio for about a month now. I have not had any experience before now. This was a budget build, so price did play a part in my purchases. Sound deadening was a bit pricier than I thought it would be So I dropped down from Mille legends in the front to the Mille pros. I stripped out my entire vehicle and put roughly 400lbs of deadener on the floor, roof, and doors. I did it in 3 layers; butyl, closed cell foam and a high density layer. I installed a component set up front and coax in the rear doors. I went with a single 12" sub for the lows. Finally I installed a head unit.
Now that I have everything installed, I like the sound be produced, but I do have a few issues with the passive crossovers and the tweeters. On songs that go up into the higher ranges the tweeters sometimes hiss. I don't want to say crackle but the sound has static on the highest frequencies. This happens on just a few songs.  Mind you this is at the highest  volume without distortion according to the C.L.E.A.N. system built into the amp. I also verified with a DD-1 (regret this purchase as it did exactly what the amps already did). My gains are set correctly. I really want to set a limit to the high frequencies being sent to the tweeters. Nothing in my set up allows for that currently.
Should I just run a inline cap to the tweeters? What cap would I need?
Should I go active crossover? Would I need a new amp for active?
I did do a ton of research, but my god there is a ton of info out there and some of that information seems to conflict and is the reason for my post.
List of items in my  build:
Amps:
Rockford T750X1bd
Rockford T400X4ad
Speakers:
Hertz Mille MPK 165.3 Pro Component
Hertz Mille MPX 165.3 Pro Coaxial
JL 12w6v3 in Manufacturer Spec Ported Enclosure
Head Unit:
Pioneer 4400NEX (I wanted wireless Android auto)
Amps:
Rockford T750X1bd
Rockford T400X4ad
Speakers:
Head Unit:
if youre not exaggerating about your install, then you have no reason not to do an active crossover for your mids/tweets. If you went that extreme with everything else, you shouldnt limit yourself with power robbing passive x-overs. You would need 2 additional channels for active if you want to retain your rear speakers and add a DSP since the deck only has 6 rca outputs and youd need minimum 7 (2 front tweet, 2 front mid, 2 rear fill and at least 1 for sub)
Thank you for the reply.
What would you suggest for the active xover and the DSP? Is there a singular unit that can do both?
Alright, so I need:
1) DSP (and laptop?)
2) Replacement 6 channel amp to keep my rear coax, or add a 2 channel amp for the rear coax. (Kids watch DVD's in rear seats so i need to maintain rear speakers)
Glad I went over sized on my amp board to fit the additions.
also, i do see where people talk a lot about putting a resistor in line with the tweeter as a backup in case the dsp's xover forgets the x-over point and lets all frequencies thru to it. youll not see nearly as much parasitic loss in the power as you would with a conventional passive x-over and still have a failsafe for your tweets
Slow it down. If this is in fact your first system you have gone way past most first-timers. Now I congratulate you and issue a warning to not "throw money" at your complaint about the tweeters.
When you say hiss and static from the tweeters, only on some songs, what exactly do you mean? Do not forget that you have many audio settings within your Pioneer head unit to access. If you're unsure of what is actually the source of this annoyance you can spend a bit of time with the equalizer and see what one band at a time does to affect a song. I'm not convinced, with the information provided, that you need to buy one more piece of electronics.
What are your audio sources? Streaming from Spotify off your phone's Bluetooth connection? HD Radio? Let us know more about that.
Need to know more info. Those are a nice set of components with solid gear backing it up. So I would look into install or how you are listening to music. If they are off axis or directed at a windshield that could be the issue. If you are streaming music or listening with a crappy aux cable that could be the issue.
A DSP will definitely give you more control and could flatten out the upper frequencies but I would not throw money at your build until you identify the problem.
They have several thousand dollars wrapped up in gear already and no sane person would do that if they didn't want immaculate sound. The added cost of a dsp would be less than what they probably have invested in sound deadening if the weight figure is correct. Why try to argue the point of a passive setup? The end result of the active will greatly surpass the passive all day long. If the cost of an additional 2 channel, dsp, cables and install isn't an issue for the op, then let them get it and be happier as an end result. Nobody with this amount of gear should be passive if no aversion to a dsp, laptop and an additional 2 channels of amplification didn't make them balk in the slightest
I'm not against a DSP but I am against throwing money at a problem without knowing the cause. Would **** to buy a DSP and have someone tune your system properly to find out the static is from the recording or source since it is only on certain songs. Guess what DSP wont fix it.
I listen to Flac audio via USB and Google Music depending on what I feel like listening to.  6.5 and coax are in the door factory locations. Tweeters are in factory location firing up to windshield. I tested the tweeters in multiple locations via the supplied pods, but I liked the factory location better for multiple reasons. I really don't want anyone to see my audio nor do I want to see my audio.
The only time I get the hiss, crackle or the static sound is at full volume and only during vocals and it is fairly rare on vocals. Adele Flac albums for example (don't judge). When Adele starts screaming I get light crackling. My head unit has the front and rear speakers crossed over at 63hz with 12db slope. I do not use the crossovers on my amps.
I purchased the additional mic for the head unit auto tuning. I like the head units auto tuning better than my tuning so I kept it with a few changes to the crossover settings. I measured the timings set by auto tune and they were right one. I haven't really played with the EQ settings myself on the head unit, and I probably should.
the issues he listed sounds like connection issue that could be anywhere between the amp and the tweeter. So it could be wiring or even a resistor in the passive x-overs getting frisky. Bi-amping good speakers is always the best way to get clean power to the driver. If the tweeter isnt damaged and the wiring is good, that doesnt leave very many options for culprits of the issue. In all honesty, @randpost its just going to sound better biamping the fronts, period
Conclusion to my problem:
I ended up picking up a T400X2ad 2 channel amp for starters. I figured I would order a DSP in a week or so to keep everything under the spouses radar. I hooked up up my front comps to the 2 channel amp to test it before installing it. The high end crackle/static was non-existent on the 2 channel amp. At this point I'm thinking it might have been a bad connection to the 4 channel amp. So I removed the 2 channel amp and hooked up the 4 channel amp again making sure all the connections were solid. The static/crackle at high volumes is present again.  I placed an ordered for a replacement T400X4ad. I didn't want to return the 4 channel amp until I tried a new unit. I installed the new 4 channel amp today (same model). It looks like I just had a bad amp because I have absolutely no issues with the new 4 channel amp. The amp I am having issues with is still  within the return window with Amazon so all is well.
I never thought it was the amp, I though that as long as its delivering power its good to go. Perhaps it was an issue with some of the internal electronics of the amp? I don't think I will use the 2 channel amp now, my stock 120 amp alternator most likely doesn't need more of a load than it already has. I am now happy with the sound in my vehicle. I may sneak the 2 channel into the wife's car with a set of Morel Ultra 602 Integra's. I've been wanting to try those and needed an excuse.
randpost
randpost
Phoenix, Az
youdoofus
