Kicker or Alpine --
Im on a budget and I built my own sealed box.
Also im more into SQ then I am SPL, (not that I would know, this is my first system)
its being powered by a Cadence TXA-6004 (600x2 @ 4 ohms) because I forgot in my original post.
LOL, those are both awesome SQ subs //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
How much power will you have?
I really don't know much about the Kicker.. Besides that it is not an SQ woofer, it get's load but is not geared towards SQ..
The Type R is the same way, and can handle LOTs of power.
I've heard L5's that sounded better than R's, but meh.
Either will work in the right box for what you want. Just make sure it's either the correct sealed volume for the sub you buy.
Kef
It doesnt have to be between these two, im just on a strict budget of >150
any other suggestions?? Maybe I dont really need that much SQ. This is my first sub and amp, and I dont want something thats going to hit so hard I cant hear my Alpine Type-S speakers.
ehh some guys on here should be able to give you better options. the L5 can pound but its not an SQ sub. its also not as much in the range of an argh but either way, im sure youll be fine since its your first. youll probably enjoy either one.
I'd take the Morel Maximo 6 over anything on your list.. 169.99 or so from Crutchfield.
23
7K
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
417
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
921
bterz
bterz
Southern California
eboutin88
Latest topics
