how do i hook these up
  • 4
wywy
26
PA
ok right now i have the Power Acoustik gothic seris 2 ch amp i was thinking of getting two L5 12" would this power them ok and what would be the best way to wire them and which ones to get dual 2 ohm or 4 ohm im confused
amp:
2 Ohm RMS:370x2
4 Ohm RMS:310x2
1600w max
ok right now i have the Power Acoustik gothic seris 2 ch amp i was thinking of getting two L5 12" would this power them ok and what would be the best way to wire them and which ones to get dual 2 ohm or 4 ohm im confusedamp:
2 Ohm RMS:370x2
4 Ohm RMS:310x2
1600w max
I believe that particular amp is stable to a 4 ohm mono load. You would need to purchase dual 4 ohm woofers to wire them to a 4 ohm configuration. You would use a series/parallel wiring configuration. As far as the power being enough, I wouldn't think that it would be enough for a couple of L5's, but I will leave that issue to someone that is a little more educated on Kicker products than I am.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
4
wywy
wywy
PA
wywy
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
