how do i hook these up
wywy
26
PA
ok right now i have the Power Acoustik gothic seris 2 ch amp i was thinking of getting two L5 12" would this power them ok and what would be the best way to wire them and which ones to get dual 2 ohm or 4 ohm im confused
amp:
2 Ohm RMS:370x2
4 Ohm RMS:310x2
1600w max
ok right now i have the Power Acoustik gothic seris 2 ch amp i was thinking of getting two L5 12" would this power them ok and what would be the best way to wire them and which ones to get dual 2 ohm or 4 ohm im confusedamp:
2 Ohm RMS:370x2
4 Ohm RMS:310x2
1600w max
I believe that particular amp is stable to a 4 ohm mono load. You would need to purchase dual 4 ohm woofers to wire them to a 4 ohm configuration. You would use a series/parallel wiring configuration. As far as the power being enough, I wouldn't think that it would be enough for a couple of L5's, but I will leave that issue to someone that is a little more educated on Kicker products than I am.
wywy
wywy
PA
wywy
