Buying new headunit need to ask question
  • 2
dalifts
4
pa
I ordered a headunit off ebay. It says it has LO/DX Controls. What are these and can u explain a little more. And how good are cyclone headunit. I just wanted somethin 2 play cd's with. Can u explain more if they are good or not. I only paid like 25. its Cyclone 160 Watt AM/FM Receiver CD Player w/Detachable Face Part #CCD18. thanks
Well, I've never heard of LO/DX controls.........but I'm going to go out on a limb here and say that the Cyclone is a POS. You can get some pretty darn good used headunits on ebay for ~$100. Granted, that's 4 times more than what the Cyclone costs, but they will be 100 times better............
But if it works for you, more power to ya.
what ^ said. amp gain setting info, test tones are at the very bottom...
250
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
892
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
893
dalifts
dalifts
pa
squeak9798
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
