Jump to content
realflow100
can the bass boost act as a crude subsonic filter if the amp doesnt have one?
Recommended Posts
like i set the low pass filter first. then set the bass boost to just over half so until the frequency that outputs the most power is around 40 to 50hz with the gain all the way down and turn up the gain so that the voltage around port tuning is set right on the amp so the subs get the most power around that frequency range. so lower than that it'll drop off in frequency like a subsonic filter preventing the subs from bottoming out? since the bass boost is on it'll drop in output below 40hz or so and the subs wont bottom out below that?
if the amp doesnt have a subsonic filter can that work?
Edited by realflow100
Share this post
Link to post
Share on other sites
please dont assume i have a mental illness. its just a question. and thats just rude to say.
Share this post
Link to post
That's some funny 💩 right there.
2006 ridgeline hu:KW ddx9903s morel 5.25 maximo comps 6.5 maximo coaxial 2 Dayton ultimax 8s 1.65 @35 amp Rf t1000x5ab
work truck 2017 international pro star Alpine ute62 hu. Amps RF t1000.5ad 4 ch mode infinity k1000  sa 15 3.84 @ 35hz or 2 type s12 6.3 @ 41 hz  or jbl s3 2.0 36hz. or nvx  vcw 10 1.1 @ 32hz  2 8 " eminence pro woofers. 2" Dayton rs52fn midrange. 1 1/8 Dayton dc28f silk dome tweeters.
Share this post
Link to post
No idea. Hope this helps...
2016 Focus ST3 - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
2010 Focus coupe 157@46hz
Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
https://www.youtube.com/popwarhomie
too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
Share this post
Link to post
No, its not a cross over and the gain is not a volume knob, its a voltage matching pot to match the HU output as an amp can make full power with the gain off if the signal is hot enough.
Share this post
Link to post
so you are trying to create a really artificial and distorted 45hz peak in hopes of having less output down low?  I'd recommend just redoing your box so you can actually play a wider range of frequencies without reaching mechanical limits.  Losing cone control and subwoofer unloading is different from bottoming out... It takes a lot of fking power to bottom out a sub so use the correct term.
09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
Headunit: Pioneer 80PRS......Mids/Highs two pioneer gm 8604 bridged, one at 4 ohms bridged one at 2 ohms bridged, one ppi 600.2 for tweets.
Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
Share this post
Link to post
Yes, you'd effectively cut frequencies below the boost frequency, but you'd be cutting everything above it too, creating a sub that is useless outside of 40-60hz.
If your goal is bad sound quality I guess you're on the right track.
Generally, the objective is to have consistent output from ~30-80hz, if it will go lower that's a plus.
Unless you're tuned at 40hz not having a subsonic filter really isn't an issue.  Even if you are tuned that high, there's not that much music that spends a lot of time at ~30hz.
'04 Chrysler Town & Country (it was cheap and I have a family)
  • HU: Stock - Scosche SLC-4
  • Comps: Lanzar Opti6c w/Opti400x4d
  • Rear fill: Stock
  • Sub: Lanzar Opti1232D 3cf 29hz w/Zed Opti1000.1d
Share this post
Link to post
mine are definitely tuned to like 45 to 50hz or something really high. 25hz and below it gets quieter and stuff starts vibrating and jumping up and down a lot. and i want to cut down stuff below like 25hz  so its not vibrating stuff so much and my subs look like they are about to jump out of the box at 14hz. they arent bottoming out but they look close to it.
is there a way I could set up an EQ/filter subsonic filter on my pc instead if that will work better?
i just have one amp going to my subs and another amp going to my stereo speakers hooked up with a Y headphone cable splitter to hook both up seperately but in the same headphone output on the front of my pc
Share this post
Link to post
14 hz? Lol. You really need to change equipment for what you're trying to do instead of trying to make that work
Share this post
Link to post
Maybe you should start over?.. you "modified" the enclosure to "30hz"
Had to repair a dustcap
Got some mechanical noises, and questionable repairs
Those ^^^^ are just the threads on THIS forum I know about.
I vote for the Wallsocket idea... :clap:
Then you'll have to start over and if you're smart... get a low-tuned enclosure
JVC KD-X350BTS, FI Bl-18v3d2, Deaf Bonce AAK 4000.1, RF 500s, Polk DB comps, Cache Preamp/EQ250A Ces
Share this post
Link to post
He'll probably just spray more water on it
Share this post
Link to post
Better plug it in the Wallsocket 1st... dem lows will be "Shocking" then...:scared:
Share this post
Link to post
You're like  a bad car wreck. Don't really want to see it but everyone slows down to take a look
Iirr you don't really listen to suggestions you just keep trying to reinvent the wheel.
Share this post
Link to post
Good bandwidth bottleneck analogy
Share this post
Link to post
i doubt you have any actual music that goes to 14 hz or 25hz literally 99% of the music out there has any material that goes under 30hz, very rare 28hz here and there.  Its probably low 30s and you dont even know the difference.  If you are just playing test tones... dont... just play music and movies normally.
How do you know your box tuning? Did you actually put all dimensions into an actual box calculator or are you just shitting all these numbers out of your ass?
Share this post
Link to post
I play all kinds of music some even have below subsonic frequencies bass i love you has some frequencies below 10hz and some other songs have super deep bass like 20hz violation and subsonic world and stuff have bass below 20hz and a song called 17 hurts
Share this post
Link to post
What ever happened to those "Terminators"?
OP is slinging advice on another forum, like a expert... guess those theories and expertise can't be held back... :suicide:
I still vote for the wall socket idea
:scared:
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
