Subwoofers work only after disconnecting and reconnecting positive speaker wire
  • 2
Charles Oliver Vetter
Hey guys, brand new to the forum. I really hate asking for help because I know just about every problem has been addressed alreadyI’ve searched and searched but cannot, for the life of me find a solution nor thread on what I’m experiencing right now. When I start the car, the amp light glows blue, but the subwoofers will not work until I disconnect and reconnect the positive speaker wire from the back of the sub. Once, the subwoofers started playing after I cranked the volume on the receiver up real high. Is this a poor connection? I’ve checked the power, ground, remote and speaker wires, I’ve replaced the plastic connector on the enclosure, switched the order of the subs (wired in parallel) but to no avail.
Thank you for reading!
-C
Hey mate,
Thanks for raising your issue here! :fro:
Looks like a faulty connection somewhere, so I suggest the following;
  • check power, ground, remote wires, from car battery, behind your head unit,
  • check RCA cables;
  • use multimeter to check resistance on the subwoofer, could be a faulty voice coil ;
  • Disconnect subwoofer output wires and use a test speaker with your amp to see if the problem persists, if it does, most likely your subwoofer is the culprit;
  • Take your amp out and test with another amp to see if the subwoofer works , then possible cause could be a fault with the amplifier;
  • Check amplifier grounding point, remember, power runs from negative to positive, hence the 12v negative ground notice! :laugh:
  • Check amplifier settings that its not high passed or the frequency is set to run tweeters resulting to low frequency being restricted to feed the signal to your subwoofer;
  • Hopefully if you attend to all of these tasks, your issue should be sorted :graduate:
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
951
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
928
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
DRBOOM
    Apr 26, 2024
    Apr 26, 2024
