T-Line ??
  • 5
MattinMO
Enlighten me, specifically speaking t-line boxes when would one want to mount inverted vs regular mount? if your a little tight on room and need the air space? Im having a t-line built by a guy for a e12v3 to play around with and he stating to mount inverted. I have no problem with that just wanted a little more feedback/input @shredder2 @THATpurpleKUSH
Just like reg ported enclosures, gives the box a tad more internal volume w/o the sub being in it. But...that's the choice of the designer. Imo, I don't care to have that option. Mine is def not inverted. View attachment 4472
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
914
MattinMO
MattinMO
St.louis, MO
THATpurpleKUSH
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
