LP filter
  • 6
Roger Wilson
I have a good JVC double din unit with most all the settings. Including control of all 7 of my speakers. I have Kenwood 6.5s and 6x9s in doors and back panel and the factory Tweets up front which actually surprised me. I have a mid priced SSL amp going to all my speakers. I have an Alpine 500 RMS amp. I thought my LP filter was lower , but it was 100 . The way I understand it , the lower the LP goes the more bass only you hear out of the subwoofer. If I am correct about that detail. Then does it make sense for me to turn it much lower to around 75 or even 50
80 is standard.  Why -- most 6.5's can pick up 80+ w/o much difficulty, and most subs sound decent going that high.
If your LPF is much lower -- you better have good quality speakers that can play pretty loud at 60-65, and your sub would have to be able to get low.  A lot of cheap subs in small sealed boxes are done (or fading fast) at ~50hz.
Mess around with it.  See what you like.  See if it matters.  Learn something.
LPF (or in this case referred to as LP) = low pass filter. whatever freq you set it to is where the crossover starts to cut the freq by either 12 or 24 db per octave not letting the frequencies above that number to go to that channel. e.g. you set it to 100, it'll, for all intents and purposes, cut everything 100 hz. It doesnt change anything on the fronts or rears, just the sub. They call it a "low pass" filter, because it lets frequencies below that number to pass. HPF is the same principle but with the opposite end of the freq band. As n2uadio said, play around with it, but going above 100 is not ideal for subwoofers
If you’re logged in the word censor is now turned off. Happy Holidays everyone!
663
You need to re-phrase the question. Are you trying to use active bi-amplification via outboard amplifiers or do you just want the recommended...
.Run HU at full pass, cross HP filter on the amp at 40-50Hz - or - Cross the HU at 40-50Hz and amp at full pass. I prefer to adjust prior to the amp
Roger Wilson
Roger Wilson
Zer0C00l
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
