2012 ford mustang shaker 500 help
  • 4
Jimg
CarAudio.com Regular
216
13
Not sure I am posting this in the correct forum section.
Looking for ideas on replacing the door speakers in a 2012 ford mustang.  Replacing the 8 inch speakers. has the shaker 500 factory system.
Will be adding some subs in the back so not looking to keep the subs in the doors.  But some midrange would be nice up front
First problem    the factory amp that runs the subs in the door.
My first option was looking at running a audiocontrol lc2i using the back speaker wires to power up and send signal to.   , run one amp to the door sub location and a 2nd amp for the subs in the trunk off the LC2i
Second problem is the mounting depth being shallow in the door sub location.
Thinking about going with a component speaker of some type.  Possible building some type of mounting bracket to make them fit.
What are the options that will work? in replacing the door 8in subs with something different.
Factory depth I think is 3.2 inches.
thinking about not going back with an 8 inch in the door
would rather go with a component speaker setup.  Has anyone built a template to do this?
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
Wiring color code should be ISO, just like American radios. If you get your vehicle specific radio harness, it should have the same colors as that...
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
560
Jimg
Jimg
Jimg
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
