High Pitched Frequency Noise from Speakers... with Radio OFF
Farkel
I'm having a problem with noise coming out of my speakers when the head unit isn't even playing music. I'll describe the symptoms as best I can to hopefully isolate and narrow down the possible issue?
1.) With the ignition in ACC mode, no music playing, there is a faint static/white noise type of sound coming from the speakers
2.) With the ignition turned to On, no music playing, there is a louder, higher pitched whine from the speakers. I recorded the video below to capture the noise:
My set up is 4 speakers, front and rear, subwoofer, an external Amplifier in the back trunk, aftermarket head unit.
Any help would be much appreciated
An older Alpine amp
I bought a pair of PAC SNI-1 ground loop isolators and plugged them into my Headunit's preamps to see if that would help... it didn't do anything. The whine is still there. The whine also gets proportionately louder when the car is on and you rev it
You have a ground loop issue mate!. Please check your grounds and re-tighten them.  Also check if your speakers are not in contact with the vehicle chassis as well. if unsure, apply electrical tape / sound deadening around the door speakers if not done already.  My money is its poor grounding point on the amp / vehicle chassis. :suave:
Decibels are a measurement how loud something is...it's not the frequency of hearing...
19
Maybe/maybe not. First it's just a guess, but components can change value with temps and this could be normal. Could also be a sign of a cap on...
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
485
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
463
Farkel
Farkel
Bay Area, CA
DRBOOM
    Apr 26, 2024
    Apr 26, 2024
