Matching amp output to PioneerTS-V10 speakers
  • 2
TalkingWhippet
CarAudio.com Newbie
Hi all.
I am finally sorting out stereo in older Land Rover Defender and am fitting Pioneer TS-V10 speakers in front dash with a Pioneer GM-D1004 amp.  Amp is 4-channel at 45W RMS and speakers rated at 60W - its physical size is main attraction as small and will do enough to boost sound in what is a noisy truck anyway.  Guy selling speakers reckons 60W for V10s is a conservative rating though and they will be happy with more input.  I was thinking that I could bridge amp output so have 90w RMS on 2 channels.  Would this be too much for the V10s - or better to go with higher output and avoid clipping at 45W?  Or am I just being overall too anxious?  I've always understood that better to run speakers near maximum rather than under power.  If go with 75%-150% rule, then range would be 45w - 90w RMS for V10s.
Views much appreciated - sorry if this is a very common kind of question!
David
bridge em....be conservative on gains, you may need some rca y connectors...just plug left rca to input on corresponding amp channel and right on other input
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
6
looks like it will work just fine. this amp would work just as well if you want to save a little money. I run one of these and a 2k as well. Both...
Thank you guys! I will lower the gains with the multimeter as I have watched the youtube.
5
For that sub.. A single sub.. You will need an amplifier to be stable @ 2 ohms, of approx 1500-2k rms or an amplifier @1 ohm stable at approx...
877
Check out the Down4Sound JP95 5-channel amp. It may be the 5-channel amp you are looking for.
TalkingWhippet
CarAudio.com Newbie
TalkingWhippet
YourNameHere
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
