Rms speaker and head unit questions.
  • 3
Lund1660
CarAudio.com Newbie
Hello everybody, I have a boss marine radio mgr350b, it has a rms of 80, has a peak power 60watts per channel. I bought two Polk Audio DB651 which has power rating of 180 watts peak, power handling of 60 watts rms. Will I run into problems if the receiver has a rms of 80 watts and the speakers have a rms of 60 watts.thank you for your help.
smh
So probably won’t hurt anything? I found it was very difficult to find a round marine radio that had any good reviews, the boss radio had the best that I could find. I would like to get a pair of 6-9s should I stay with speakers that have 60 rms or find something different?
you could run just about anything ya want to polks probably aren't too bad. Boss is pretty bottom of the barrel equipment but they're kinda like cock roaches hard to kill.
get a rockford marine amp and do not use the decks power. youll never look back and from there want to amplify everything. it makes that much of a difference
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
847
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
873
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
3K
Lund1660
CarAudio.com Newbie
Lund1660
youdoofus
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
