Build Component Suggestion & Set up questions
  • 2
ps2cho
LA
Hi guys,
I have a 2016 Audi Allroad with the factory Bang & Olufson 15 speaker setup. Overall sound quality is pretty good, but the subwoofer in the trunk is basically inaudible. I want to add an amplifier and enclosure /w subwoofer to the system to get the bass I need. I'm not looking for competition grade, or window shattering, just want to add some decent bass to my factory setup and then I'm cool.
Question 1) I have two choices of subs I already own, which is better for my setup? Both sitting in the garage for 5+ years and want to use one of them.
A) Infiniti Reference 850W (REF850W) - 8" Sub
  • 8" Single 4 Ohms Reference Series Subwoofer
  • Power Handling:
    Peak: 800 watts
  • RMS: 200 watts
[*]Impedance: Single 4 ohms
[*]Proprietary Reduced-Depth Steel Basket
[*]Frequency response: 30-400 Hz
[*]Sensitivity: 91 dB
B) Alpine SWE-1043 -  10" Sub
  • 10" 4-ohm subwoofer
  • frequency response: 29-1,000 Hz
  • power range: 100-250 watts RMS
  • peak power: 700 watts
  • sensitivity: 84 dB
Question 2) I want the slimmest enclosure I can get within reason so I don't take up a ton of space in the trunk. Based on which sub from above, should I go with a sealed or ported box?
Question 3) I'm not 100% sure on the install - I am disconnecting the factory subwoofer and want to use that wiring. Is all I need a line output convertor (LOC)?
If so, I don't understand the difference between getting a $20 RCA converter/adapter like the PAC LP7-2 vs going with the $75 Audicontrol LC2i. What's the benefit to the LC2i, or is there none with my plan? I understand how to wire up the amp's power/gnd/switched 12v, that's no problem, its just how I take the factory sub wiring and convert that over to the amplifier
Thanks!
Your deck should have rca out for the amps hook upbut if none then a converter I would think the cheapest one would work fine. Audiocontrol brand idly tends to run real pricy. I would find out the suggest box sizes for said subs before making a choice since your wanting smallest box.
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
847
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
786
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
968
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
833
ps2cho
ps2cho
LA
Dragonsyph
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
